| Hello,
I am renovating a house I just bought for my family. It is a wonderful 2.5 story built in 1904.
I got Red Top Gauging Plaster. I mixed it up for the sand float finish. After some finishing test in the closet I see that they probably used a wood float originally in the house so that is what I am using. To the issue... I did my first wall tonight with the skim coat and floated it out with the wood float, now I see that I was thin in a couple of small areas. The Red Top calls to be a 1/16" thick and doubled back over with pressure. I have some smaller areas where I can see the through to the old plaster.
Thank you in advance,
- Posted by sombreuil_mongrel (My Page) on Fri, Aug 13, 10 at 0:10
| If it was mixed properly (Lime putty, sand and gauging) which isn't exactly apparent from your post, you may or may not have problems where it does not meet the recommended thickness. The possibility exists on the thin areas that it will evaporate dry without curing. Water is needed for the lime to cure, and when the water evaporates quickly (more likely in a too-thin application) the plaster reverts to a powder state instead of setting up hard. You'll know in a day. If you can powder off spots with rubbing, you need to apply it thicker. If the problems spots are quite small in size, you could wait until after priming, then, treat as a drywall repair, with regular mud. Casey |
| Excellent. Thank you. Yes, the mix was done precisely as instructed on the Red Top Gauging Plaster bag (lime putty, then gauging and sand - exact proportions from bag). I put two coats of Tammsweld on the wall before applying skim coat. Thank you for your input. Any other advice on this is greatly appreciated if there is more. Jeffrey |
| Sorry for doubling up here... Let's say after 24 hours I just want to apply another thin layer of skim coat.... What would be the steps at that point? Would I put another coat of the bonding agent on again and then skim coat? I have only done a small section in the bathroom as I am hoping to get this technique down before doing the larger areas of the bathroom (none larger than 30 sq. ft of wall area). Jeffrey |
- Posted by sombreuil_mongrel (My Page) on Fri, Aug 13, 10 at 14:21
| Since it's a lime plaster, you have a little time where it will bond perfectly well without benefit of a bonding agent, but the sooner the better IMO. Wet it down first. Casey |
Return to the Old House Forum
