Is This An Acceptable Way to Insulate Attic?
Posted by chipster_2007 (My Page) on
Wed, Aug 24, 11 at 9:47
I have an unfinished attic that has several items in it making it impossible at this time to remove the floor boards and add insulation. There presently is some old fiberglass batts that have lost a lot of their loft. Before this heating season begins, could I add some mineral wool to the roof rafters and minimal exposed wall areas for the time being until I can remove flooring(boards) and install the mineral wool there? Do I need to cover this with drywall on the ceiling since this does not burn? If this is acceptable, what would be the best way to attach it to the rafters? When I install this in the floor, would I have to remove the insulation I added to the roof? It will be easier to get this done before winter sets in that to install in floor. Please comment. Sorry, I don't like cellulose for a variety of reasons.
RE: Is This An Acceptable Way to Insulate Attic?
As a temp measure, you would be better off unrolling the insulation right over the floor boards for the entire attic. You want the insulation as close to your conditioned space as possible. You will want unfaced insulation for this.
When you have time to do it right, just roll the insulation back up and reuse it under the floor boards.
+1
If you need the area for storage, you can build up a false floor on top of your existing structure to get the proper depth of insulation.
Return to the Old House Forum
