Wed, Jul 16, 08 at 23:05
| At each corner of the house there should be a diagonal brace let into the wall framing. The boards are not structural. When plywood came into the market the diagonal bracing was discontinued. |
- Posted by sombreuil_mongrel (My Page) on Thu, Jul 17, 08 at 7:16
| I don't know what you mean by plank. Do you mean a "box house" where there are no proper studs, the walls are formed ny 1x12 noards nailed to the sills and the top plate and (usually) wallpapered inside and horizontal siding outside. Other type of plank construction is the walls are stacked horizontal planks (1x6's) this other style is sometimes called "corn crib" construction, as the walls are immensely strong, able to resist extreme side loads. If your house is stud walls sheathed with planks, there's nothing unusual about that- the studs bear the load, the planks provide racking resistance and give a flat base to nail the siding to. Box construction houses should not be able to stand, but they do. They rely on the strength of the fasteners, all of the roof load is transferred through the nails; no wood bears on wood as in conventional construction. If the nails rust out, the structure will fail. The box-constructed house should be modified with great care. Usually, modernizing these houses involves installing studs from the inside, making for conventional structure at the expense of smaller rooms. Casey |
Return to the Old House Forum
