Return to the Old House Forum
Concrete squares in yard
graywings (
Sat, Jul 4, 09 at 21:50
| There are three concrete squares in my yard that I can't figure out. They are all the same size, 17 inches square with a 9 inch square open space in the center. They appear to have been set in a straight line down the center of the lot side to side. On is on the edge of the front porch, one is approximately in the center of the yard front-to-back, and one is at the rear of the property.
The house was built in 1919. Any idea what these could have been used for?
RE: Concrete squares in yard
| They may have been taken from a construction site somewhere by a former owner in the hopes of finding a use for them. Now they're your problem. |
They look like chimney block, to quickly build a flue. They are a little on the small side. How tall/deep are they? Casey |
| The one in the center of the yard, which looks like it is set on another one, is 8 inches high. Picture below. Like haus_proud, I first thought they were brought in by a previous owner looking to use them as planters. But when I realized the placement appeared to be in a straight line front to back, I went looking for a purpose for them. However, now that I look at the photo below, everything around that block is part of a 15 year old extension to the house. The slab to the left could not have been poured if the concrete was there, right? So I guess I will go back to thinking that they were brought in as garden planters.
| I think they are old concrete blocks for building flues. The slab to the left could have been poured, and then the block could have been put in place (or replaced). They should work fine for planters. |
| "I think they are old concrete blocks for building flues." That would be a very poor flue. Flue tile is fired tile to resist the heat and make sure flue gas cannot penetrate. |
brickeyee- Yes, but with flue liner installed! Since they're not going to be used for that purpose, it's not much of an issue... |
Brickeyee, poor indeed! But they still make 'em. The more I think about it, it's not big enough for a flue block. I think it was a pier block, capable of being filled with rebar and concrete for a very solid pier. Casey |
| "Yes, but with flue liner installed!" Not large enough for much of anything, especially if you tried to line them. That would take at least another inch off the dimensions. "I think it was a pier block, capable of being filled with rebar and concrete for a very solid pier." Far more likely. Concrete has huge strength in compression, and minimal rebar and grout would stabilize a column. |
