| We are re-siding our home with HardiPlank CedarMill, changing the color of the house from deep brown, to a light gray. We are replacing all the wooden doors with ThermaTru ClassicCraft(woodgrain look)fiberglass doors. We are thinking of staining the door a light-medium oak. Not sure how this would look with the woodgrain look HardiPlank but if we do not like the look we can paint over the stain. The door has a rustic look and ThermaTru offers dummy black strap hinges with it but their price is pretty darn high. As the hinges are metal my husband thinks they may rust anyway. So he is thinking of getting some brass hinges, around 18 inches long or so. I cannot find any solid brass on the internet. Does anyone have a source for this? Or are we relegated to a black decorative strap hinge?
Nancy
| Nancy I aplogize that I did not get a clear picture in my mind. So my reply might make no sense. Two things occur to me. So what you can do are what I would consider. If you care enough then make some brass covers for the hinges. Brass is a metal easily hammered into any shape. my area of expertise are materials: I'm a scientist. This is where I feel lacking. I can't recommend which ones but I can say a few helpful things. 1. avoid asking at home depot. If you want real answers The kind of problem you're solving is new to the adhesive Her's a useful link if you use adhesives. http://www.thomasnet.com/products/adhesives-393009-1.html assuming you chooose not to use adhesives you could If I've gotten you too involved I apoligize. Brass hinges are not something I see anywhere except Lastly I do know that the BBC4 site has had great shows http://www.channel4.com/4homes/on-tv/the-home-show/ or http://www.channel4.com/4homes/ I'll check back on you in a week and see how things are going. Andre |
| duh. now that's I've awoken and read your post clearly it seems that you still won't find hinges but making coverings from sheet brass could work. And as far as adhesives you won't ruin anything by trying 1. a high quality silicone adhesive. This is flexible and allows for the different expansion rates of the two metals. 2. Soldering. Soldering to steel is possible and brass solders very well. It would cost much more. Who to make the brass pieces? - A. horse shoe makers- people who shoe horses. They hammer B. A stained glass maker. Someone who makes large pieces and been in business for a while. They're used to C. Think along those lines. Shaping pieces into shape and Sorry to waste your time above. |
| "If the hinges carry weight they need to be steel usually." Brass hinges work just fine. |
- Posted by nancyk (zukituck@yahoo.com) on Fri, Jul 31, 09 at 12:38
| The hinges are decorative, not weight bearing. On the ThermaTru fiberglass door, the hinges are stuck on with an adhesive. The ThermaTru (decorative) hinges and clavos are a zinc alloy, which may rust. We just thought a good brass could be attractive and would not rust. This is a non-functional hinge. The below is a link to a picture of the door, we will not be getting the sidelights or handle. http://thermatru.com/products/entry/fiberglass-entry-doors/ccr/index.a spx
| Zinc does not rust. Zinc plated (galvanized) steel hinges will rust since the plating is never perfect, but it can take a while. |
- Posted by gary_bowman (My Page) on Wed, Feb 20, 13 at 20:20
| Hi everyone, I am a novice in this field and I need help finding a good supplier for my hinges. I'm interested in buying hinges from here www.spep.com but they don't sell to individuals, it's a $150 minimum order. I need these models: Stainless Steel Strap Hinges Cheers, |
| You can order brass in just about any thickness 7 width you would need to make real or decorative hinges from numerous metal dealers. Be prepared for some rather pricey stuff though. Many will provide cut pieces of stated width and thickness. Brass is not all that hard to cut and shape. Unless protected it will turn brown (or green if enough of various chemicals are around). You can also purchase 'brass black' and 'brass brown' to color the metal. |
Return to the Old House Forum
