| Our home was built in 1947 and has plaster board walls.
What is the best way to hang drapery rods? My husband does not want to have gaping holes in the wall. The stud finder does not work well on these walls so finding studs is a problem. |
| What do you mean by "plaster board walls"? Gypsum drywall (Drywall is actually a trade mark IIRC)? Since there are always studs on each side of a window (possibly multiple in a weight bearing wall) is is not usually very hard to place drapers rod fasteners into the studs. |
- Posted by slateberry51 (My Page) on Tue, Jul 26, 11 at 16:05
| Anyone think a hilti toggler might be good if she wants to spread the brackets out past where the studs would be? |
Here is a link that might be useful: Hilti toggler
| If you are past the studs any number of expanding anchors can be used. Molly fasteners still have one of the larger footprints behind the wall since they expand in four directions. A lot depends on how heave the rods and draperies will be. if they are very heavy (say over about 50 pounds) you may need to install blocking behind the finished wall fastened to the studs and then repair the wall.
Return to the Old House Forum
