Return to the Old House Forum
Putting a 12' toilet in a 14' rough In Space
chipster_2007 (
Thu, Jul 7, 11 at 12:05
| I would like to put a 12" toilet in a 14" rough in space because I would like to use a toto toilet but don't have the additional cash to buy the unifit system. The choice of toilets with this unifit system is also limited. I know there will be a small space behind the toilet. My questions are: are there any problems/potential problems I could run into doing this? What could I use as a brace/bumper for the back of the toilet to give it the support that the wall normally does? The back wall is tile. Your thoughts would be appreciated. Thanks |
RE: Putting a 12' toilet in a 14' rough In Space
| I have this situation caused by a dim witted plumber who unfortunately was a friend. The tank of a modern two-piece toilet is not intended to rest against the wall and should not need it for bracing. In any case, the tank lid would touch first and possibly break flip up. The only drawback of your plan is a space as large as 3 inches behind the toilet. IMHO you will soon forget the savings and wonder forever why you bought the wrong toilet. I think about replacing mine every day. How much does the 14" Toto cost? |
| We lived with that for a week and then ripped out the toilet, gave it to Habitat for Humanity, and installed a 14" It does not go with the sink like the first one did, but at least it does not look like it is sitting in the middle of the room! I could not stand it, as we have a very small bathroom. |
| Can you bring the wall out 2" or so to resolve the gap issue? |
| Post this in plumbing- there are these offset collars that can adust spacing of the toilet from the wall... I cant remember how ours was done, it might have been taking it down from 14 to 12. Having the toilet sitting out that far is just WRONG!. |
| Kashka,,, I am a plumber and for the record the offset flange you describe is now prohibited by code. |
| The offset adapter fits above the floor for toilets that are designed to use it. The toilet would have an 11" actual rough in and the adapter would be placed to decrease or increase the rough in dimension by one inch (to 10" or 12") by being reversed. Any other kind of 2" offset adapter would require having enough room to offset below the floor. In general it is not a good idea to make it any harder for waste to pass through this critical part of the system if you want to avoid backups. |
