How to fix the ceiling?
Posted by rae0101 (My Page) on
Mon, Jul 28, 08 at 11:31
We gutted the kitchen all the way back to the wood walls. It wasn't pretty wood that was meant to be seen. It had been covered with cheesecloth and wallpaper, then several coats of paint. I've put up sheetrock, taped, floated, textured and painted the kitchen walls. (The walls throughout the rest of the house had been drywalled years ago.) The problem is that the ceiling in the kitchen is this same wood. It's painted, and it looks terrible. There are gobs of latex caulk that are clearly visible, the seams of the boards are even, not offset, there are nails and DEEP marks from the hammer everywhere, and the boards aren't level. If I put sheetrock on the ceiling, I don't see how it could possibly come out even and without seams. I've wondered about applying joint compound directly to it in a plaster pattern, but it would have to go on so thick that I know it would crack. Is there a different product that wouldn't crack with a heavy application? Real plaster maybe? I've never used it. Also, I like the faux tin ceiling tiles from Home Depot, but that's more than I want to spend, and I don't know how I'd get those to look even, either. If anyone has ideas about how to fix this, I'd really appreciate it.
RE: How to fix the ceiling?
Have you asked a drywall pro about it - may be a better bet than you can imagine (tho' I personally can't say one way or another).
We had an uneven brick wall sheetrocked over by a professional years ago. He nailed thin battens to the wall and levelled those, then attached the sheetrock. It is very smooth and seamless. Perhaps this method would also work for your ceiling.
That's exactly what I would do too.
Return to the Old House Forum
