Mon, Jun 19, 06 at 16:14
| I have a house from the 1910's or so. The original house which is now the living room has steel windows, the largest one is a casement(?) has the opening in the middle where you push it out and attach a rod to hold it open. The others are all fixed. They are steel and have disappearing caulk or whatever holds them in. No window people have ever seen them in my area and there is no way to get them to be energy efficient I suppose. Is it hard to at least re caulk and do we have to take all the old stuff off or do you just patch. Any ideas who to call or how to follow up on this. I know this sounds a bit vague. I'm a single mid 50's ex new yorker who is only gradually learning how to care for this wonderful house.
Marcia |
- Posted by sombreuil_mongrel (My Page) on Tue, Jun 20, 06 at 20:41
| Hi, Industrial materials such as the steel factory windows started to make their way into homes in the teens and twenties, so yours is a very early example. They were originally glazed with linseed oil putty, which even in steel sash does dry up and fall out. For a complete redo you'd need to remove the putty, steel clips that actually hold in the glass, and then do whatever sanding and priming that the steel needed, then you'd reglaze with new clips and putty. The putty line on these sash is enormous, I recall that the putty is a 5/8x5/8 triangle, so the amount of putty will be like four times what a wood sash would require. The choice is yours whether to use glazing putty or painters putty (made with linseed oil). Consider having interior wood storm windows fitted. The house I grew up in (built in 1936-8) had two sets of these windows, and they were very inefficient. The large pair (each 6' x 8') were covered with condensation and ice most of the long upstate NY winter. Casey |
- Posted by sophietime (My Page) on Fri, Jun 23, 06 at 18:01
| Thanks Casey. These are the only windows in my house without double pane but they are unique and unusual. There are 3 fixed ones and one with a projecting style opening, like they had in industrial new york buildings. They have paint also on the outside that I would like to strip somehow and put some protection on them. Have you ever stripped paint from the metal windows? Marcia |
- Posted by sombreuil_mongrel (My Page) on Fri, Jun 23, 06 at 19:32
| Old paint will stick to metal for a long time. It would be inconvenient to chemically strip it, and heat is ineffective because the metal conducts the heat away. Your best bet would be to sandblast. But realistically, just scrape and sand. Use a red oxide primer, or a rust converter. If the former, reprime with regular oil-based exterior primer before top coating. If the latter, follow their instructions, different brands of rust converters have different priming requiremets, but most ask for a latex primer. Oh, yea, glaze after priming, then top coat once the glazing skins over, and of course "bed" the glass in a layer of putty. Casey |
- Posted by optimumwindow (My Page) on Thu, Apr 30, 09 at 16:24
| check out these steel windows at http://www.reliantsteel.com also join us and learn about steel windows here at: http://groups.google.com/group/thermally-broken-steel-windows?hl=en then visit us at http://www.optimumwindow.com |
Here is a link that might be useful: OPTIMUM WINDOW MFG
Return to the Old House Forum
