Mon, Jun 20, 11 at 9:55
| I have some downspouts that drain into terra cotta underground piping. One of the downspouts is draining very slowly. I plan to try to try to augur out the piping - - if i can get it clear, I need to replace the terra cotta cap that the downspout was mounted to. Does anyone know if you can purchase something like this? Where?
If this does not work, I am consider a rain barrel or draining the downspout into the yard. Thanks. |
- Posted by carol_from_ny (My Page) on Sun, Jun 26, 11 at 15:14
| I'd try a brickyard since what you need to replace is terra cotta. It might help you greatly if you can either take the old one with you or take a pic of it with you when you go shopping for one. We had downspouts that went into terra cotta piping and that piping went into the ground. The pipes were filled with all sorts of stuff. Instead of trying to keep it clean we are going the rain barrel route. |
- Posted by columbusguy1 (My Page) on Sun, Jun 26, 11 at 17:56
| Have you thought of trying a patching compound like the stuff to fix broken concrete--it might work. I think it comes in small tubs at the box stores, a vinyl product? |
| We were pretty sure our terra cotta underground piping was failing - So disconnected them from downspouts & did corrugated plastic type above ground to the downspouts - & away from the house. Much better system. I sure the terra cotta was filled with all sorts of things underground |
Return to the Old House Forum
