removing old caulk from brick
Posted by dawner (My Page) on
Sun, May 20, 07 at 18:59
After replacing the old windows in our house, a bead of very dried up caulk and paint was left there on the brick where the old window used to be. Does anybody know how to get it off without damaging the brick, which unfortunately is not a smooth brick but very rough?
I've already tried a wire brush and all I got was orange brick dust. Any suggestions? Thanks, Dawn
RE: removing old caulk from brick
One of two things...
Try gently heating it with a heat gun. You don't want to get the heat gun close enough to bubble it, only enough to make it pliable so that you can scrape it off.
The other thing would be to freeze it with liquid nitrogen and then pop it off with a sharp wood chisel. Not recommended as you can really do some damage to yourself if you get that stuff on you.
I don't know if this tool would be of any help for this particular application, but if it doesn't work you're only out twenty bucks.
Do a google search for 'putty chaser' and you'll find a number of vendors.
Here is a link that might be useful: putty chaser
The first time the carbide in the putty chaser touches the brick it will shatter, throw shrapnel everywhere, and may be out of balance enough to bend the shaft.
Try a heat gun.
Did you end up finding a solution? Our windows were caulked very poorly and need to be redone, but I really worry about tools that will remove the caulk damaging the window cladding or the soft sand-faced brick.
Return to the Old House Forum
