| I own a 1910 up/down douplex. I rent the upstairs, and live downstairs. My last tennants were evicted for being disrespectful of the property. I've repaired most of their damage, now I have some hardwood damage to deal with.
The hardwood is typical of 1920's, so I would say its probably original to the house. One spot looks like a burn spot, and the other looks like a potted plant that regularly overflowed (perfectly round, and very dark). I would love to repair them without have to refinnish the entire floor. Any thoughts? Has anybody ever tried wood bleach? It looks awful - a couple boards that are "ighter" in color from the bleach would look better then these stains.. |
| It can be anything from not bad to repair small areas to nearly impossible. For wood that is actually damaged (and black spots sound like iron staining) it may be better to pull some closet floor boards up and use them for the repair.
| Try this cut/pasted CURE: |
| "water from continual source leading to mildew (black)" It is also very common to get black stains in oak floors from iron reacting with the tannic acid in the wood, long before mildew is the issue. When carpet tack strips are removed from hardwood floors (especially oak floors) it is very common to see a black spot around every nail hole that was used to fasten the tack strips. It is iron-tannnic acid, not mildew. |
Return to the Old House Forum
