U-Sand
Posted by llll2008 (My Page) on
Sat, May 24, 08 at 13:35
I have read a lot of posts about how (relatively) easy it is to refinish wood floors (DIY) with a U-Sand machine. I went to rent one, and the man at the rental store told me I needed to rent two machines: the U-Sand for the majority of the floor, and a different machine for the edges. Is this true? I had hoped to just use the U-Sand everywhere. Thanks!
RE: U-Sand
The U-sand gets close to the edges but you may still need the edge sander to clean things up. Adding the edge sander is not that big a deal. I re-did a porch floor and tried both the traditional drum sander and the U-Sand. Being a DYI-er as well I found the U-Sand much easier to get a good result.
Diane
RE: U-Sand
A hand orbital sander will work fine. You'll only need it in the corners. The edges will be fine if you use shoe moulding. Buy extra sand paper!
Return to the Old House Forum
