| Hello, All! DH and I are renovating a turn-of-the-century gabled ell in a historical neighborhood. I stopped in a nearby salvage place last week and they had marble window sills removed from a nearby school. Looks like Carrara marble to me--white with fine gray veining.
On the underside of each sill are 2 or 3 blobs of mortar which held the window sills in place. Some of the mortar blobs also have a single nail sticking out. How can I remove the mortar? Should I use acid? Should I try to chisel it off? More info: I got these sills for $15 each, they're about 4' by 6', 3/4' thick. They will look perfect if I can use them as open shelves in my kitchen (I plan to use aged brass brackets to support them). The tops of the sills are polished (glossy), the bottoms are smooth but not shiny (honed?). Because it is an old house and we're selectively remodeling, I don't mind if they don't looke brand new when I'm finished with them. If I have to use some sort of acid on them, I don't mind if they eat away at the marble a bit. I just want a simple solution, but one that won't destroy them. In fact, if my 'solution' left them with a honed instead of polished look, I'd love it. I prefer honed to polished, especially for this house. I took a picture of the sills to post, but I'm not sure how.... Thanks! |
Here is a link that might be useful: Our Crumble Abode
- Posted by hollysprings (My Page) on Wed, May 30, 12 at 10:46
| Chisel off the old mortar very carefully. Not only will an acid solution not remove blobs of mortar, it will etch the marble badly, leaving it difficult to clean properly and with holes in it if you leave it in contact long enough. Be very sure that your brackets are sturdy enough and are fastened into the studs. Marble shelving is quite a bit heavier than wood shelving. |
- Posted by millworkman (millwork4u@gmail.com) on Wed, May 30, 12 at 12:59
| other than chiseling there is no simple solution. |
- Posted by MichaltheGirl (My Page) on Wed, May 30, 12 at 13:19
| Alright, then, chiseling it is. Any suggestions on what sort of chisel to use? What sort of surface should I place the marble on when I try to chisel it? Something to absorb some impact? Wood? Don't worry, we'll be sure to screw the brackets into studs. And these are beast studs, too. We tore through the plaster on the other side, and these are very thick, oak studs. |
| "other than chiseling there is no simple solution." You can also just cut off the edges. Marble is not as hard as granite (or any number of other stones) and carbide tooling with water is often adequate. |
- Posted by sombreuil_mongrel (My Page) on Wed, May 30, 12 at 19:59
| If you start chiseling, you're going to find out right away if they are sturdy enough to be shelves. Shocks from chiseling are going to be a good test. Personally I could not see a marble shelf narrower than 8" having sufficient strength to support itself for very long, let alone any weight. Marble lacks flexive/tensile strength unless reinforced by "rodding".. I think a diamond grinder wheel would be the best removal method. Acid will eat marble faster than mortar. Casey |
- Posted by VictoriaElizabeth (My Page) on Tue, Jun 5, 12 at 9:11
| Oooh. Sounds like a lovely find. Personally? I would only use one tool for the job-- my husband. |
Here is a link that might be useful: We too have a crumbling abode
- Posted by lazygardens (My Page) on Tue, Jun 5, 12 at 20:09
| Get an old wood chisel, or a stonemason's chisel. It should be dull, but with a nice beveled edge. Also get a small iron hand sledge - 2 or 3 pound will do. Hold it loosely in your hand at a very shallow angle (almost parallel to the marble) and tap it from bare marble into the blob of mortar. Vary the angle of the chisel if nothing happens. If you are lucky, most of the mortar will pop off. |
Return to the Old House Forum
