| I have a small section of a wall where a piece of wallpaper was torn off by a child. If we still had the piece, I would try to patch it back in, but we don't. In the same room, there are areas covered by the same wallpaper which are out of view. Is there a way to cut out a piece and transplant it to the area which is visible? Thanks. |
- Posted by theporchguy (arthur.giammetta@comcast.net) on Sun, May 11, 08 at 19:10
| eddieg 2008, Yes you can do it. Be careful to match the piece you need when you find out where your taking it from. Oversize the piece. You can either just paste it over the area thats missing, a fair job. Or you can wallpaper razor knife through both pieces of wallpaper and remove the new piece and then carefully remove the edging remaining. Now paste the new piece right in place. Patience helps. Let the warm water have time to work its' way into the paper. Good Luck, All the best, The PorchGuy |
Here is a link that might be useful: My Album
Return to the Old House Forum
