Shingled roof needs bigger slope
Posted by petoola (My Page) on
Sat, Mar 20, 10 at 21:15
We have a mobile home with a 12 x 56 addition across the back. The addition roof spans about 20 feet from the peak to the end with a very small slope. My husband has been shoveling the roof every winter but it's a chore he'd like to be done with.
We'd like to put a metal roof on and make the slope much higher so the snow would come off. He's going to extend the new peak out over the peak that is there now, which would give the back the slope it needs. Would he have to take the shingled roof off first or could this be done over the shingled roof? Any tips or suggestions welcome.
RE: Shingled roof needs bigger slope
The main thing is if the stucture can support two roofs, though the metal may be lighter than a shingled roof. Is there already a roof under the roof that spans the addition?
I have an old house, it has two roofs in most areas. They would extend a porch on one end and then just build another roof right over the top of the old one. I have "under roofs" that have two layers of ceder shakes and two layers of asphalt shingles.
If I ever did something like that, I would at least strip the under roof. It's been a real pain dealing with things in the attic because of it - but that is because I've been doing lots of stuff up there (running vents and such) that required cutting through the under roof.
BTW- for airflow you may need to cut holes in the under-roof near the top edge so the air will circulate.
Cathy
Return to the Old House Forum
