HELP!!! What have I gotten myself into???
Posted by kindred_ny (My Page) on
Sun, Feb 26, 12 at 18:44
OK, so I discovered that the trim in my house was painted by the people who owned the house about 50 yrs ago. Since it was originally NOT painted, you guessed it, I have decided to strip the trimwork, oil, shellac and maybe varnish it. I started on the basement doorway, and 8 hours later I still have green paint in the grain of the wood.
Some questions...
1) I've heard people mention a very good heat stripper. Would someone please give me the name and approximate price range?
2) I've used a "friendly" paint stripper, but it's not working well. There's still paint in the wood. Should I use a 0 grade or courser steel wool to wash it after using the stripper? I'm using 0000 grade now and it's not really touching it.
3)I have heard one should avoid sanding the wood if at all possible, to retain the patina. Is this correct?
I feel like I've just taken on a hurculean task. There are 8 windows and 5 doorways in my downstairs, and the first door is only 1/4 done (with paint still stuck!). ANY info to help this job go easier and faster would be SOO much appreciated!!! I want very badly to bring back my home's intended beauty. She just looks blah with white painted trim. THANKS!!!
RE: HELP!!! What have I gotten myself into???
And I forgot to mention the 8" baseboard around most of the downstairs! lol I think it's finally happened. I have officially lost my mind! :)
I use a Porter cable heat gun that I got at Lowes for about $40. It works well for me, but I can't tell how it will work for you. Depends on the wood species and paint composition you have. 40 bucks isn't a huge investment to find out....
50 year old paint is likely to contain lead and that might limit you choices in removal methods.
Here is a link that might be useful: Lead Paint Removal
If the trim is an open grained wood such as oak - and that's what it sounds like - a heat gun or chemical stripper will not remove paint embedded in the grain. The only solution is lots and lots of sanding. Once that's done, the kind of finish you propose will not look as good as it would have if it had been applied to unpainted trim from the start - all the sanding will inevitably glaze the surface.
Only you can decide if it's worth the time, effor, mess and expense , but if it were me, I'd resign myself to painted trim.
It's been my mission to remove about 8 layers of paint from all of our trim, and it can be done to varying degrees in different ways. Search this forum for discussions of paint stripping; there have been lots. To answer your several questions I'll just describe our process:
Rough strip the thick layers: this can be done with a heat gun (inexpensive but may release lead fumes and can start fires), an infrared paint stripper (Silent Paint Remover, expensive but probably safer at least with respect to lead, but can also burn wood), or with various chemical methods. We've just gotten the IR stripper, but have previously used both the heat gun and chemicals. We're very pleased with the IR unit.
Of note here is whether you can work outdoors - that is to say, whether you have removed the trim to work on it or not. We removed almost all our trim and have done almost all that (outdoors), but finding the time/opportunity to work on the stuff we left up is.... eh, not happening. On the other hand, if you work outdoors it is seasonal work - fall and spring. Too cold in winter, too hot in summer. Another downside is that trim can be damaged by removal. But working flat rather than upright and trying to protect floors: for me, priceless.
Our chemical paint stripper of choice is EZ Way, something we found at a trade show years ago and that you have to mail order from Washington State. We like the liquid; the semipaste is awkward, I find. But other off-the shelf strippers do work for this stage, including those with methylene chloride, which is one ingredient I've avoided from the outset. I've also tried several of the friendly stippers, and they work too - eventually. You have to find one that will stick to vertical surfaces if you are working in place.
With the EZ way, I dip shop cloths in it, wrap it over the wood, cover it in plastic, and wait an hour or so. Other chem strippers too will benefit from being covered with plastic - but not all.
There is usually an interim stage of getting the bulk of the colour off, and then there is the final stage of getting it out of the pores. This is usually - apply stripper, wait, use 3m scrub pads and later cloths, and just keep going until it's all out. You need a LOT of pads and cloths - the aforementioned blue shop towels are good, and later just plain paper towels too, but strong ones.
A toothbrush is also a very useful tool at this stage, rather than your steel wool.
The reason we like the EZ Way is most evident at the end, which is where most strippers need a clean-up with a different rinse - water or I think paint thinner. EZ way needs no separate clean-up because it evaporates, and you can keep going with it until your pores are as clean as you like. Before we discovered EZ Way we adapted to still seeing traces of the paint! That's an acquired taste, and I'm here to say, you can live with it and it is still better than trim covered with the old paint.
It will happen that you strip wood and find it doesn't look that good (bad grain) or that you can't get the final colour out. In that case, you might decide to repaint and then I still find it worth stripping because the multiple layers of colour totally conceal the moulding profile, and in our case, old paint drips are all over the place and I can't stand them.
I think something called Kutzit might be similar to EZ Way but I'm not sure. Key point is to look for something that doesn't require water or other clean-up to get rid of stripper residue.
Plan to do this over a period, possibly of years. I am NOT going to tell you how many have elapsed for us! Maybe do one opening at a time, so that if you pause, it is bearable to look at for a while :-)
Oh, and sanding... I don't think we have ever sanded unless we have applied filler to the old nail holes or other damage. I assume it's all lead paint, for which sanding is contraindicated. It wouldn't be the patina so much as the profile I'd be afraid of damaging, and the wood was finished to start with so should not need it for smoothing. EZ way does not raise wood grain so that's another advantage.
Karin L
I don't think it's oak. The PO's that painted said it was "ugly wood, chestnut or something". It's very grainy. but seems to be closed grain. Think I will try a courser grade steel wool first.
I can completely empathize with you. I have so much to do that I decided to go for a faux bois finish on mine that I will do myself. Lo and behold, my son was stripping some spots out of curiosity and it was originally done in a faux bois!
You know, a nice creamy white trim can be quite beautiful...just in case you decide it IS too much work.
Otherwise, keep thinking how lovely all these wood trim and moldings are going to be, when you finish. And you'll be able to enjoy all your hard work, every time you walk into your home :)
In 1965 my parents bought a 1936 craftsman bungalow with lots of oak woodwork that had been finished "blonde" - the filled finish that makes it clear the wood is oak but otherwise is a lot like paint.
Ultimately, I believe she got all the finish off with a combination of lye in water and a wire brush. I don't recommend the approach - my mother is not a patient woman - but it doesn't look bad thirty-some years later.
Years before that she enlisted all the kids over the age of about 6 in stripping 9 layers of paint from the woodwork in another house. We used the heavy duty chemical that would have been most available in the late fifties-early sixties. The name Zip-strip comes to mind but I could be wrong. I'm amazed that any of us are still alive! (Mom is 88 and healthy - takes no medications.)
Finally, woodwork at Geo.Washington's mansion at Mount Vernon is finished faux bois in important, public spaces.
If you decide you want to strip, you might also consider removing the wood to a more convenient location (like sawhorses with plastic sheeting underneath).
It is not as hard as it might appears to remove trim without damage, pull the nails through the back side, clean it up, then just install it again.
After spending hours on hands and knees trying to strip trim in place, it is a lot easier on you and the trim to remove it.
Definitely use a coarser steel wool to get the paint off.
0000 grade is for gentle cleaning of gunk off finishes.
Zip Strip has been my go-to paint stripper for the past 25 years & I highly recommend it.
Zip Strip Premium is a classic methylene chloride paint stripper.
They work VERY well, but can be dangerous.
Use them with a LOT of ventilation.
Outside is best.
Inhaled methylene chloride fumes attach to the heme in your blood that carries oxygen preventing it from working.
Tie up enough heme and you pass out, just like with carbon monoxide.
Have a heart condition and you may die.
It is really nasty stuff, best used outdoors.
In my house, after stripping all our doors I became pregnant and stopped stripping with the intention to start again after the baby. Well five years later, I have decided I quite like the look of the dark doors with white trim, molding and windows. Historically many homes from the twenties had dark stained doors with white trim, so maybe start with the doors and see if you want to continue later with the woodwork. Good luck and I too used a cheap heat gun from HD with great results.
I'm scared of heat guns--vaporizing lead paint, igniting the back side of the wood you're working on and burning down the house? No thanks!
I tried methlyene chloride stripper, and that was slow going, even though it was supposed to be the fastest of any chemical stripper.
For my latest project, I borrowed a speedheater (aka silent paint remover) IR stripper from a friend. They cost $400. Ooof! Compared to anything else I've done, it's a dream to work with, and I'd like to have my own. But the price...$400, for one tool with no moving parts? A metal cage, some quartz bulbs, and a switch? Seriously, a huge chunk of that money must be going into marketing and liability insurance. They should try Geico or something.
Then I found this post:
$40 for parts, fun assembly with the kids, and you're good to go. Even better, see how he has his switch off to the side where it won't overheat and burn out? This is an improvement over the speedheater; my friend has had to replace his switch twice already.
Here is a link that might be useful: diy Quartz paint remover
"I tried methlyene chloride stripper, and that was slow going, even though it was supposed to be the fastest of any chemical stripper. "
The typical directions opn MC stripper are woefully inadequate.
You really need to cover it after application to prevent evaporation (MC is very volatile, boiling point 103F with a high vapor pressure, 47 kPa at 20 �C).
The 'wax' and other additives claimed to be present do not perform well enough to be effective (they only make clean up harder).
Even a simple layer of Saran Wrap over the stuff speeds it up nicely.
For me the deciding factor would be - is there enough shellac as the first layer on the wood. If so, then some sort of heat removal makes that first layer melt and the layers on top slide off really easily. f not - I would seriously think about painting - either cream or go the other direction and go dark (saw a pic recently of a house with this dark warm almost black charcoal color for the trim/wood that was stunning. It looked both modern and reminiscent of Victorian dark wood at the same time.
You could be have paint in the grain because the shellac was sanded off or wore off prior to painting. In that case the paint might have gone into the grain then, and be literally impossible to remove.
OR... sometimes the chemical method is really sloppy and it could be the residue got in the grain as you were scrubbing it off. In that case if you use heat to remove most or all of the paint first, then you wont have htat problem -g oood luck.
BTW, Ive sometimes removed paint knowing I would be painting it over. If there's a lot of lumpy layers and paint drips then it can be worth it to have a nice smooth clean surface to paint over.
Who told you chestnut was "ugly"? That's kind of a strange opinion.
I can tell you what you've started is MASSIVE! I have almost completed stripping a 3000 square foot home, 6 french doors, 20 doors, and about 40 windows (which we ended up paying for someone to do the windows). 1 year later, I'm still working on it and I have worked this like it was a full time job, with overtime - literally, it has been almost 7 days a week, 8+ hours a day, and I did this to paint it fresh, not stain it!! It's monumental, but now looking at it, it looks beautiful. Trouble is - once I started I couldn't stop, because the good stuff looked so good, and the other stuff - terrible, plus... the previous owner slapped on latex over oil and it was peeling everywhere. GOOD LUCK!!
Oh, I used a homedepot heat gun, I think it was the $40 Porter's gun.
Return to the Old House Forum
