Floor structure is in question
Posted by oldhousetime (My Page) on
Mon, Feb 1, 10 at 16:33
Well, I am in a dilemma. Bought an old House, 1905, gutted the 2nd floor bathroom and would like to put a cast Iron tub in. The tub with water will weight about 500lbs. When ripping out the bathroom, the subfloor , which was diagonally placed 2 x 6s that went from one room to the other, have been taken out. The floor joists have large holes from old plumbing plus holes for new plumbing. I am worried that the diagonal subfloor boards did more then act as just sub flooring, but distributed weight to a larger surface making less load in the bathroom...
Can I sister the joists and call it a day or should I think about something more invasive.
This problem has been keeping us from moving forward.
Thank you in advance.
J
RE: Floor structure is in question
This sounds familiar
Sistered joists will restore the integrity of the structure. Modern plywood will give adequate support for a tub. BTW, the time to easily do this was before the plumbing. It is sometimes challenging to fit pipes through boards. It is generally impossible to fit boards around pipes.
Just a note on joists - the old growth lumber was stronger than what you will fine at Home Depot. If you are going to use new lumber, make sure your joists are spaced properly by modern standards.
Return to the Old House Forum
