Insulation for home built 1954-- advice, recommendations PA
Posted by yan19454 (My Page) on
Wed, Feb 10, 10 at 10:51
I have one brick house built in 1954. the attic has little insulation in Philadphia area. I am looking for the advice and recommedation for insulation.
Thanks.
RE: Insulation for home built 1954-- advice, recommendations PA
Check out US Department of Energy recommendations by zip code here. (Click first link.)
Dr. Lstiburek of Building Science recommends min R60.
If you have the space, I'd suggest doing the work in this order:
1) Seal all air gaps between the attic and interior. In the '50s, there was virtually no attention paid to this.
2) If there is a coat of oil paint on the ceiling, you may forego a vapour barrier in the attic.
3) Provide sufficient roof and soffit vents.
4) Provide that the air route to the soffits remains clear. Use, for instance, pre-made styrofoam baffles.
5) Insulate with blown-in cellulose to a minimum of R 40.
Return to the Old House Forum
