foam-like patching found under old wallpaper
Posted by civ_IV_fan (My Page) on
Mon, Feb 27, 12 at 9:47
it isn't terribly important, but i'm wondering what the heck this stuff is.
i removed some wallpaper from a wall in my stairwell and found some typical plaster damage underneath. what was atypical were the previous repairs. in one section, an area about the size of a horizontal piece of paper was missing the original plaster. you wouldn't know at first glance, because the area was completely patched.
but as i poked at it, i found that from the surface of the wall all the way to the lath (this stuff was keyed into the lath) was a patching material that was almost like styrofoam. you could stick a fork in it if you wanted to.
any idea what the heck this might be? my plan is to remove it all and fix the plaster properly -- just curious about this oddball material.
RE: foam-like patching found under old wallpaper
They might have used the spray-on expanding foam insulation and smoothed it over to fill the holes, then skim coated or spackled it.
I found shoe box cardboard, glued over the holes in the plaster under several layers of wallpaper.
Return to the Old House Forum
