Bulb broken off in fixture
Posted by capecodsookie (My Page) on
Wed, Dec 30, 09 at 13:20
How can I remove the metal base of the light bulb that has broken off in the fixture? I tried the potato trick - it didn't work.
Thanks
RE: Bulb broken off in fixture
Turn off the circuit at the panel and use needle-nosed pliers.
I agree, don't wimp out. Put gloves, preferably kevlar lined, and get the lamp base out of there! If needed, use tools!
I recently had the same problem and used needle nosed pliers but rather than grabbing the metal base, I opened them inside the base. They caught just enough of the base to screw it out of the socket.
