| We live in a rowhouse, which means limited windows and potentially dark rooms. We have finally decided to pull the trigger and get recessed lights installed. I have a few questions from the GardenWeb experts. 1) We have an L-shaped dining room with track lighting that is relatively large and currently a bit multi-purpose (it's now serving as half a kids area). We are not going to commit to a chandelier or a ceiling fixture. I want to put in recessed lighting along the sides of the room (similar to where the track lighting is already) and later on, a chandelier could be added if desired (thinking about resale). 2) We have a smaller living room that does have a simple ceiling fixture but is dark. I want to sprinkle some recessed lighting in this room as well, but assume that recessed lights + ceiling fixture is OK? 3) Want to add recessed lights to our dark bedroom as well. Are there any major no-nos with putting recessed lighting in this way? Are there any useful rules of thumb to follow when determining placement of recessed lights? Thanks. |
| I'm not into trends, so we pretty much do around our place as we really want it. This year I put 21 Lithonia LED recessed throughout the dining/kitchen/living/hall. Wife wanted the chandelier eliminated in the foyer, and installed a 5" recessed there. The dining room is set up with a ceiling fan/light, 4-5" recessed on a dimmer, then 2-3" recessed on another dimmer. The living room we added a ceiling fan/light, and 4-5" recessed lights on a dimmer. We're very happy with the outcome. I must say, when I was determining where to place the lights, the ceiling looked like a grid. I shot drywall screws into the ceiling, & ran twine from end to end. Two of the lights we ended up adding was in the hallway after I put a 5" recessed light there. We added 2-3" recessed at each closet. In the enclosed space, the recessed just don't light up like a globe does. Next is the bathroom. I can run all 21 lights, & still be under the watts used for our 4 bulb vanity light. Makes it seem all worthwhile. |
- Posted by janesylvia (My Page) on Wed, Dec 19, 12 at 22:55
| Roof35, thank you very much for your detailed description. I also plan to have recessed LED lights installed in my living room and family rooms controlled by dimmers. May I ask what dimmer you used for your LED recessed lights? I saw HALO LED ML56 (LED 5" or 6" trims, 600 lumens, 3000K), is IC rated and airtight. Lithonia Lighting 5" recessed LED is IC rated, but did not mention airtight. Does it matter? If I choose a can with airtight feature, would it solve the issue that the recessed light itself is not airtight? Is Lithonia equally as good as Halo, although the Home Depot salesman recommended Halo? Thank you very much. |
| Greetings! Sorry for not getting back sooner. I work in the highway department, and winter is our busy time. The dimmers I used was the, Diva 150 Watt Single Pole/3-Way CFL/LED Dimmer, White. No hum, buzzing or anything else I read people had problems with. The Lithonia is airtight, all it is in little stick on's inside the canister. I can only comment on Lithonia's service, which I had to use for one light, which started to hum on me. Lithonia was _outstanding_! I really like the looks of them too. |
Return to the Lighting Forum
