Help! Flos Fucsia Pendents stopped working
Posted by nsmontreal (My Page) on
Wed, Dec 9, 09 at 9:43
Has anyone else had this problem? I thought the bulbs had simply burnt out but when I replaced them they still didn't work, leaving only one of the original three illuminated. Should I try to reconnect them at the base? Frustrated--Flos lights are expensive and meant to last, non?
RE: Help! Flos Fucsia Pendents stopped working
If two lamps went out at the same time and replacing them with the correct ones, making sure they are properly seated in their sockets, didn't work then the next step is to check the wiring at the canopy.
