Landscape Lighting Questions Answered
Posted by chr1ssy (My Page) on
Mon, Dec 1, 08 at 0:45
Hi,
I'm so glad they added the new lighting forum.
I am in the landscape lighting industry and if you have questions regarding landscape lighting or low voltage outdoor lighting, I would be happy to help any of the forum members. I can help with layout, design, choosing fixtures, where to buy, troubleshooting, etc.. You can either email me or contact me through my website for free advice.
Note: on our website, we created a 'Learning Area' that shows step by step instructions on all topics and phases of outdoor lighting projects.
Good Luck!
Here is a link that might be useful: Landscape Lighting Instructions
RE: Landscape Lighting Questions Answered
Hi. Welcome to the forum. I have just finished building my house and would like to tackle the landscape lighting as a DIY project. My initial thought was a spot light on each column and then some sort of pathway lighting for the walkway and the parking pad.
The only exterior lights now are recessed cans under the porch.
Let me know if you would like some additional pictures or have any questions.
Do you have any ideas on what type of lights should be placed where?
Here is a link that might be useful: House Picture
Drsung,
1. I would put some spotlights aimed up at each column as you suggest. Have the wattage bulbs on the two main entrance columns slightly stronger (i.e. 50 watts for the two columns by the door, 35 watt on the others) to emphysize the entrance columns. If you feel lighting up all the colums is excessive you can either move down to 20 watt bulbs or just do the 2 by the door then the corner columns.
2. (2) Pathlights (China hats or Coneheads). One at the beginning of the pathway from the parking area, the other in the bed closer to the stairs (stagger them on opposite sides). Plant in bed --not in grass (putting fixtures in grass interfers with lawn cutting, they get hit by mowers, etc.).
3. You could put 2 flood lights with 35 watt bulbs aimed up at the large oak tree so the lighting isn't over concentrated on the house.
4. You'll need a transformer, cable (12/2 cable) and splice connectors. A 300 watt transformer would work, but a 600 w will give you room for expansion in the future. Using a multitap transformer (it has outputs from 12 volts to 22 volts depending on which terminal you attach the cable wire to) enables you to adjust the output of the lights and compensate for voltage drop. Transformers at big box retailers are only 12 volt (not multi-tap), so if you have many lights or a long run (like out to the oak tree on the side yard), the lights will be dim. With a multi tap you can attach the cable to a higher output terminal so all the lights are bright and even.
5. You could add a wall wash to the building on the left (use the flood light fixture but with a 20 watt bulb).
You can find these types of low voltage landscape light fixtures many places on the web (sorry, we're not allowed to post links in forums).
Aluminum fixtures are cheaper but brass will significantly outlast aluminum in the outdoor environment.
Hope that helps!
Here is a link that might be useful: Learning area that has detailed instructions for DIY landscape lighting projects
Thanks for your post. It was very helpful. I also spent some time on your website and it is very informative and helpful as well. I have a couple of more questions. I have no doubt that I can hook up the wires and make things work, but unfortunately I don't have much of a creative side!
1) Should I light up the columns on the sides of the porch as well, or just do the 6 across the front?
2) I have included another picture showing the garage (building to the left). Would a single wall wash flood be enough or should I extend things out into the bed along the driveway?
3) There will be a crape myrtle tree in the bed in front of the two corner columns. Should the floods on the corners be in front of the column, in front of the tree, or both?
Thanks again for your insight and contribution. Your website was very informative for a landscape lighting newbie and I plan on placing an order once I get my needs nailed down.
Here is a link that might be useful: House 2
1. I would light up all the columns including the ones on the side.
2. Depends on budget and how well you want to do it. Be4st way would be 2 path lights along driveway towards garage, and a wallwash aimed at front corner of garage and one that is aimed at area between the garage and house. This will add safety and visibilty by the garage and connect it to the house without over lighting it.
3. Both--lights on each column, plus a separate spotlight up at each Crepe Mrytle.
Good luck!
Thanks Chr 1 ssy! You solved a long puzzling problem for me.
Hello,
I'd appreciate any advice on lighting the front of my home. I am considering 6 flood lights, between the windows, and perhaps a small one of the side. Thank you very much. I hope I was able to transfer the picture! Thank you.
Here is a link that might be useful: House picture
Your home could benefit from a larger sconce on each side of the front door, mounted lower on the wall to help it look like an entry and from some path lights in the planter at the edge of the lawn between house and lawn. Select path lights where you can't see the source of the light and let it make pools of light on the lawn. Don't put them too close together. It's OK to have isolated pools of light to add interest. If your shrubs will get taller you could eventually light them from the front or back light them and graze up the front of the house with a soft light. If the tree can be laced (trimmed to expose more of the structure) you could softly up light it.
Note: up lighting is considered light pollution by some. However, it adds a lot of interest to a yard because we don't typically see things lit that way. Soft low wattage fixture to keep it understated will be best.
Hi,
My question is strictly regarding quality. We've had path lights for many years but have had to continuously replace a plastic lens here and there and repair the wiring to keep all of them working. Can you recommend a high quality, low-maintenance, long-lasting brand that will last for upwards of 10 years?
Thanks,
Laura
There are several that could satisfy. Pros have favorites for different reasons. FX is as American made as you can get and medium priced. BK Lighting is top notch and more expensive. SPJ Lighting has a lot of different chemically aged finishes that will continue to beautifully patina but is of somewhat lower quality and cost than the other two. There is a lot of excitement in LED fixtures right now but the quality of light is not quite as nice as Xenon and there is risk trying LED with low end companies because no one is sure yet how the LED and driver will survive for years out in the environment. Some companies, like BK, are making extra efforts to seal their fixtures and move the heat away from the driver. There is a huge difference in the way these companies design their LED products so stay away from cheap LED landscape fixtures.
Here is a link that might be useful: FX
We are having a pool put in and the landscape architect drew low voltage lighting schematic for us also. I'm planning on doing the lighting myself to save $$$. The architect says his favorite brand is Nightscaping which seems very $$$. Is this brand $$$ because of the cable or the actual lights? I don't want to cheap out the project but do I really need the most expensive brand what are some other brands to consider? Is all low voltage cable the same? For example I can go purchase the Nightscaping cable or I can go to Home Depot and purchase a roll of cable, any difference? Help!!
Nightscaping is considered a middle range brand. Cable is a pretty standard item if comparing the same size.
We stopped by our local FX dealer today and ordered lights for our front yard. The quality appears to be very good and the selection/finishes were excellent too. I look forward to enjoying our new lights without a lot of maintenance.
How does Vista rank in the pecking order? We are looking at a mix of FX (LM-20 step light in sidewalk, and CL-35 downlights in the arbor over our patio), and Vista (perhaps 8230s for sidewalks, and 5241 uplights for some trees.) All in black, of course.
Vista and FX are both quality brands. However a major (or bigger) factor regarding quality and longevity is the material of the fixture. Aluminum is not a good material for outdoor lighting fixtures as they are guaranteed to corrode--period. If you are concerned about quality and longevity you must go with brass or copper. The trade off is they cost more, but they are essentially a permenant solution.
I'm impartial but I truly believe you get the best quality for the price from Volt solid brass fixtures at our site landscapelightingworld.com. See the Top Dog brass spotlight or any of the brass pathlights like the china hat or conehead path lights.
Here is a link that might be useful: Wholesale low voltage landscape lights brass
I have a question - what are good resources for 120 volt (not low voltage) outdoor lights, specifically deck lights that are recessed where the upper level transitions to the lower level one step down? I like the rectangular ones, either with a vent-type cover or glass/plastic, but haven't been able to find anything but low voltage. Our ex-electrician ("ex" being the operative word) wired the area with 120 v.
Even though he ran for 120 volt, that can easily be used for 12 volt lighting. The transformer will need to be installed between the switch and the fixtures. I just converted a very large project that was wired that way. We had the electrician install an outlet controlled by the switch he had already installed and used the romex wire he had pulled to wire the fixtures. So it is possible to do , you may need a new electrician if you can't find the fixtures in 120V. Can you post a picture of what you had picked out or post the product number and manufacturer?
The link below has solid brass, quality step lights (rectangular with the brass grate) like you mention that can be ordered as 120v or 12 v specifications.
They are expensive, but you can mount them every other stair if you have a long flight of stairs.
The other option is to do as mentioned in the reply above, use the existing 120v, plug in a transformer (or mount inline), then from the transformer run 12v step lighting. Note: you need the 120 v line there any ways even if you are doing 12v in order to power the 12v transformer.
Here is a link that might be useful: solid brass step lights for stairs
If you have any questions about low voltage landscape lighting I would be happy to answer them. Add'l there is a learning area about installing at the link
Hey Chr1ssy,
Are you still offering suggestions for landscape lighting?
If you have any questions about low voltage outdoor lighting I will be happy to assist you. I have also found a web site I think could be helpful with low voltage landscape lighting. It provides info about planning, design, purchasing, and installation. (and more) Fell free to visit lowvoltage-outdoor-lighting.com
Billy
Here is a link that might be useful: Low Voltage Outdoor Lighting
I went to your website but couldn't fins my answer under installation tips.
I have about 20 Malibu lights from Home depot in a backyard patio. They are showing their age after 15 years and need an upgrade. My biggest complaint is they are never straight in the ground. Is there a better quality light that can be install so the frost doesnt push them up/over etc? Is there a better way to install the lights?
Hey Marvin, it sounds like the issue is of the stake that the fixtures you have, as well as the quality of material that they are made of. As Chr1ssy has said previously, you should really try for brass fixtures. They are just more dependable and reliable. If the frost is keeping them from staying straight, maybe you just need a stronger stake. Like a trident stake. Check out the link below.
Here is a link that might be useful: The stake and lighting fixtures you're looking for
We are about to install landscape lighting at our new home. We are looking at 10 path and 16 up lights. We found a brand that is solid brass but I have never heard of the brand. It is called VOLT anyone have any knowledge regarding this brand. The other brand we are looking at is FX
