Wed, Nov 3, 10 at 22:22
| Husband installed a new outdoor light fixture which is square shaped and hangs on a chain. Does anyone know a trick or how to get the light fixture to hang so that it is perfectly "squared". The fixture is hanging over the front door and turns just a little to the left, which is driving me nuts. Appreciate any help, thanks! |
| Usually the chain is fastened to an eye on the fixture canopy. Breaker off, remove the canopy from the box, loosen the nut holding the eye in place, rotate eye a few degrees as desired, re-tighten the nut, refit canopy to box. Repeat if it's still not hanging as you like it. |
Return to the Lighting Forum
