kitchen lighting update causing color problem
Posted by freshman (My Page) on
Wed, Nov 10, 10 at 20:13
We are updating a few things in our kitchen and all was well until I replaced two recessed lights with two pendant lights over my island. We still have recessed lights around the perimeter of the kitchen (most of which shine directly on counters) and over the kitchen table area. The recessed lights are 4" cans, and we are using 50w halogen floods (PAR20, 30 degree spread) in them. The new pendants have incandescent sockets with a 100w limit. My new counters are a speckled Silestone (Blue Sahara), and the specks are a mix of warm and cool colors. My problem is that after replacing the cans with the pendants, the island counter looks like a completely different color than the perimeter counters! The perimeter counters look warm; the browns/beiges/caramels take over. However, the island counter looks very cool and grey!
I've been buying all different types of incandescent bulbs for the pendants to try to achieve the same warm look for the island counter but I haven't found the right bulb. I've just about concluded that the difference has something to do with the fact that the flood lights in the cans are PAR and the other lights I've tried in the pendants are not, but I still don't know what to do about it.
Can anyone help me solve this problem? Thanks for any and all advice!
RE: kitchen lighting update causing color problem
You have gone from recessed to pendant lighting over the island resulting in a focused pendant as opposed to the defused light provided by the cans. Are the pendants on a seperate circuit so they can be dimmed by seperately?
Do you live in an area that might have a Lamps Plus store or some other professional lighting store. Perhaps your answer might be found there if one exists that would solve your problem.
Did you try an LED or a flourescent in the light? I was surprised at how I liked the flourescent color better in my pendant than the incandescent. Now I just need to go buy a dimmable one.
Thanks for the suggestions.
Texasredhead: with non-flood lights in the pendants, it seems the light from the pendants is more diffused than that from the cans. I can get the same color on the island counter by putting PAR 20 halogen floods in the pendants, but then I've really got a "spot" of bight light on the counter instead of the overall light I want. This is happening because the pendants are so much closer to the counter than are the cans. I've talked to a couple of light bulb companies today and they don't really have a solution for me.
Marcydc: I have not tried LED or flourescent lights in the pendants, but maybe I should. I've tried just about everything else!
Satco makes a lamp called a 50Par20 "soft par" .
Thay have sand blasted the lens of the lamp, so you'll still get the same colour output from the lamp , but no "hot spot" on your floor or counter.
These soft pars are the only lamps I use for general or ambient light.
Normclc, I like the sound of that light. I'll look for it. Thanks!
