Flexible Track Lighting Preference?
Posted by puppymomfl (My Page) on
Wed, Nov 16, 11 at 20:07
We're considering flexible track lighting intallations in our dining room and dinette. The dining room will be a simple s-curve, but the dinette will be a loose spiral. Does anyone have an opinion as to manufacturer? Tech and LBL have been recommended. Are there others? What are the pros & cons? Thanks!!
RE: Flexible Track Lighting Preference?
Following is another possibility
http://www.ledlightingfactory.com/LED-Linear-Lighting-Strips.htm
There are 2 main camps
low voltage - typically flexible LED strips. Disadvantage - the strips will not bend in the required plane
line voltage Disadvantage - could be costly.
The alternative is to build a cove/ some curved covering and use straight lighting systems such as t5 /t4 fluorescent or LED.
