Cree Ecosmart - Will optional trim fit?
Posted by numbersjunkie (My Page) on
Sun, Nov 4, 12 at 16:18
Just installed 3 new Ecosmart LED downlights from HD in my upstairs hall, and they give off too much glare. Does anyone know if the trims Cree makes for the CR6 will fit the HD version? Will this help the glare, or should we just try to put them on a dimmer?
Thanks.
RE: Cree Ecosmart - Will optional trim fit?
Haven't tried it, but to my knowledge the Ecosmarts are identical to the Cree-branded units except for the shorter warranty and lack of commercial Energy Star certification; phsyically they are the same, so I'd expect the Cree trims to fit. You may want to call Cree and verify though.
Thanks for the response. Yes, that was my understanding also, but I just wanted to be sure before I ordered the trims - to see if anyone has actually added them and if they helped reduce the glare. The ones in my kitchen are fine even when on full brightness - but ceilings there are 8 ft. These are in my upstairs hallways which is open to the LR & Entry and so maybe that is why they bother me.
