| We live in a "builder's special" house. My bath is about 5 x 7 and wasn't properly designed: for one, the only light is a double arm light above the vanity mirror (which isn't even a medicine cabinet.)
Is it possible to replace this with a unit that has arms that come down the side of the mirror? (I believe Kichler makes one, but I can only find one style.) I need side lighting, but cannot do any rewiring or screw with the drywall. Also, while I have an overhead vent and fan, I would like to replace it with one that has a light attached. Would this be complicated? Thanks. |
| "We live in a "builder's special" house. My bath is about 5 x 7 and wasn't properly designed: for one, the only light is a double arm light above the vanity mirror (which isn't even a medicine cabinet.)" Sounds like a standard design bathroom. "Is it possible to replace this with a unit that has arms that come down the side of the mirror? (I believe Kichler makes one, but I can only find one style.) I need side lighting, but cannot do any rewiring or screw with the drywall." You have to get power to the lights somehow. Either buy independent sconces or a mirror with the lights attached. There is no magical way ot getting powere to those lights. Either the wire is there or it isn't. Sounds like a simple job for an electrician. "Also, while I have an overhead vent and fan, I would like to replace it with one that has a light attached. Would this be complicated? " Not complicated, but it will likely involve an electrician installing a second switch so that light and fan are controlled separately. Don't run them off a common switch. |
Return to the Lighting Forum
