Christmas Tree lights - Help!
Posted by char35 (My Page) on
Sat, Nov 27, 10 at 12:36
Our 8 yr. old "prestrung" tree lights have only a few lights coming on this year. It was fine when we put it away last year. Any suggestions on how to test them, replace them or should we just get a new tree?
RE: Christmas Tree lights - Help!
Are they the very small lights?
While some have a built in connection (in each bulb) to keep the entire string from going out when a single bulb fails, they do not work well when multiple bulbs in the strong have failed.
A battery powered bulb checker and some time going through every bulb might be worth the trouble.
Yeah, use a bulb checker for your type of lights. If your lights (as most pre-lit trees) are incandescent mini-lights, you may have had a few fail.
As for replacing the tree, I would only do this if the tree itself no longer fits your needs. Frankly, before doing this, I would consider removing the pre-lit strings and just trimming the tree with replacement strings of longer-lasting LED lights.
