| So, I'm planning on installing a motion light on the 4 corners of my house- any recommendations? My electrician says 110 degrees isn't sufficient, but what is? Anyone have a motion light that works well and isn't too expensive. The ones from Home Depot and Lowe's don't seem to get very good reviews, but not sure about other places....ideas? |
- Posted by michoumonster (My Page) on Tue, Nov 27, 12 at 21:48
| no personal experience, but I have read good reviews on the RAB motion sensor lighting. |
Here is a link that might be useful: rab motion light
- Posted by EATREALFOOD (My Page) on Wed, Dec 12, 12 at 0:34
| Not to hijack but any recommendation for a motion light that runs on Solar (to be hung on a outside wall )? |
| Heartily recommend RAB as well, after having gone through some mid range, to the most expensive lights they have at both big home stores - all of which are frankly, awful in terms of reliability and durability. I bought one of these (see link below): installed it, tested it, and was so impressed I ordered two more. Just spectacular build quality, and not but about $10 more than the most expensive (junk) at HD or Lowes. Not to mention aesthetically impressive, with the bold, modernistic design (but not too out there, just enough to make you appreciate that it's not the same old ugly Heath/Zenith stuff that you see on every rental property). I would have preferred their $400 model, but wayyy too much for my budget, especially considering I need about 4 of these. I paid around $100 each. |
Here is a link that might be useful: RAB Stealth Motion Detector Lamp
| Use two bulbs at each corner. you need to cover around 270 degrees 360 - 90). |
| I'd mix-match products. I'd use a RAB Stealth motion-detector(since you want to cover more area with motion), however, that's the most exensive part of that brands fixture at around $100 each. And I tend to use Lithonia brand halogen fixtures. 2 lights per fixture, 150-watt bulbs. The fixture is more low-profile and puts out a lot of light. |
- Posted by landscapelighting (My Page) on Tue, Mar 5, 13 at 17:47
| I install a ton of motion sensors. Everyone posting is on the right track. RAB is the way to go. I use the RAB STL360H. If you want to convert it to LED,GE has a 1000 lumen PAR38 LED lamp that replaces a standard outdoor flood lamp. John Cambruzzi |
Here is a link that might be useful: STL360H specs on RAB website
| Will it operate with typical motion detectors? They use the same electronics as dimmers in many cases, and the bulb must be compatible with dimming (even if it is only off/on). |
This post was edited by brickeyee on Fri, Mar 8, 13 at 11:15
- Posted by janesylvia (My Page) on Mon, Mar 11, 13 at 15:02
| Kbedwards and Landscapelighting (John), thank you very much. I ordered the RAB Lighting STL360HBW Super Stealth 360 Sensor with HB101 Bullet Floods. Are there any cheaper energy efficient bulbs besides the GE PAR38 LED flood lamp? Thanks. |
| Dunno...I bought two LED bulbs for one of my RAB units, just to try them out, so I just picked up whatever they had at Home Depot at the time. I think they were about $30 a piece, so $60 total for two LED floodlight bulbs (and they are BIG). The normal, non LED floods are what, around $7 each? I have the feeling that the cost/efficiency ratio is not quite there yet, at least on the consumer side. Now if you want to feel better about using less energy, knock yourself out. But when you have 4 or 5, dual head units like I do, if I upgraded all to LED, it would cost me $300 just for the bulbs! And that is assuming that none fail, or that some kid doesn't get happy with a bb gun and decide to take one or more out. Still, looks like prices on LED stuff is dropping pretty steadily, so we'll get there. |
Return to the Lighting Forum
