Mystery about a ground wire (photo)
Posted by sooz (My Page) on
Sun, Oct 17, 10 at 22:25
We changed our our flush mount ceiling light for a semi flush one that allows us to use a higher wattage light bulb.
The ground wire is a mystery, though, as it only came out of the old light fixture itself and was not inside the square electrical ceiling box (not sure if that's the correct term).
The old light had a ground wire that ran from the ground screw in the metal hanging bracket (mounting strap? plate?) to a metal part of the old light.
There is no ground wire coming out of the ceiling electrical box! Is that normal? It just has the black wire and the white wire. Anyway, we removed that old ground wire.
Then, we attached the new round hanging bracket (mounting strap? plate?) that came with the new light, matched white to white, put one of those plastic twisty cap things to merge the bare wires and then covered it with elec tape, and did the same with the black wire to "black" wire.
Hmmmm, where is the ground wire? I see the green ground screw. Well, the ground wire comes out of the tippy top of the light fixture, along with the black wire and the white wire, all of which are INSIDE the part of the canopy/glass/lamp that we attached to the plate.
Is this the right way to do things? Is it safe?
I thought the ground wire was supposed to come out of the electrical ceiling box along with the black wire and the white wire.
Did we do this right, or are we in trouble?? If it's not right because we don't have a house ground wire, how do we fix it? I guess we haven't had a house ground wire since 1987 ...
Thanks for any help!
RE: Mystery about a ground wire (photo)
The ground wire might be hiding behind the j-box in the ceiling. If you cannot find it there, just take the ground from the fixture and connect it to the green screw. The j-box will act as the grounding source. Seems like the previous owners figured that as well.
Thanks so much for the info! (whew!)
Smiles,
Sooz
"The j-box will act as the grounding source. "
Only if it is actually grounded.
