Tue, Oct 27, 09 at 17:33
| I'm wanting to buy some under cabinet light bars, specifically xenon light bars. I'm trying to decide between low voltage and line voltage and which brand to use. My electrician has already run romex wires for 6 under cabinet lights. Each wire will connect to each other through romex so that they are all on the same switch. I'm looking at the WAC BA-LIX-2 and the BA-X2. Any suggestions on which under cabinet light bars to use? Thanks.
Kasey |
- Posted by azlighting (My Page) on Tue, Oct 27, 09 at 22:19
| I would suggest using a frosted lens with these fixtures as they tend to "scallop" if the counter is somewhat reflective. It looks like fixture BA-LIX-2 can be connected to another fixture via accessory BA-IC. I would recommend that over wiring each individually. |
Return to the Lighting Forum
