4' center-center plugmold
Posted by aliris19 (My Page) on
Tue, Oct 11, 11 at 16:32
Hi yall -- does anyone make plugmold with 4" between outlets?
TIA
RE: 4' center-center plugmold
Why so close?
The shortest I recall was about 6 inches, except on small 'power strip' type items (cord and plug connected).
corner cabinet with 22.5" available underneath. At 6" apart that leaves only 3 plugs: not worth it! But if they were closer together...
Install 2 parallel strips?
"Install 2 parallel strips?"
Yeah, stagger the outlets and you'll get one every 3"! If you line up the strip so that you have a plug closer to the end, you might be able to fit 4 plugs in an 18" span.
"corner cabinet with 22.5" available underneath. At 6" apart that leaves only 3 plugs: not worth it!"
How many things do you plan on using at the same time?
The NEC requirement is every 48 inches (no place more than 24 inches).
Hi yall -- It's not a question of having multiple appliance going at once, but not having to unplug things.
Staggering sounds like a great idea but I don't want the thickness (width).
In that location I've decided to skip the plugmold; just couldn't get it to work. There are wall sockets instead. Pity. I still think there would be a market for undercabinet not-ugly, not-heavy strip mold, but oh well.
Thanks for the ideas, all.
"It's not a question of having multiple appliance going at once, but not having to unplug things. "
So you want a cord forest?
Well, they might not stay plugged in always, but I'd rather not be switching things back and forth, here and there. It's like having a spot for everything in drawers. Underneath the counter it's not as if they're in the way at all ...
Anyway, it's not happening for a variety of reasons. Personally, I think they're far less onerous than wall outlets, especially disrupting a backsplash, but I understand my taste is not as others'. I've been thinking about it and figure maybe it's because I spent many formative years playing at a lab bench! I think I just think strips of outlets are the way they're supposed to be. Or something.
Anyway, thanks all for the suggestions and thoughts and help.
