Wed, Sep 28, 11 at 23:52
| I bought a wall sconce online that had it's ballast removed (yes, im not happy about it), and now I need to replace it so that I don't have to pay another $300 for another lamp. Can someone please help me figure out what the appropriate replacement is? I cannot find the same item for sale anywhere. It also seems like the output voltage is incorrect (made in China).
| The ballast type must match the lamp type and quantity. If you know what lamp it is supposed to be then search for its match and don't be concerned about brand of ballast. The input voltage of 120V is correct for USA residential lighting circuits. Output is what the lamp requires. Write down everything the lamp says. |
| 14W T5 lamp (1) 120v 600v output. Rapid start electronic ballast. . |
| How about the following http://www.advance.philips.com/documents/uploads/literature/Section 1.pdf |
Return to the Lighting Forum
