| Recently I installed 4 dusk to dawn CFL light fixtures on the front of my home. These fixtures replaced standard incandescent fixtures that have worked fine for 30 years. I tried to use screw in dusk to dawn controllers, but they didn't work very well and didn't last long, so I decided to install new fixtures with built in light sensors. The installations worked fine in 3 locations, but I have burned through 3 fixtures on one outlet. The last fixture was one that I relocated from another box where It worked fine. But sure enough, this 3rd and last installed fixture failed again. Once the fixtures fail, they don't work in the other locations where the fixtures work properly. The outlets are all on the same circuit controlled by a 2 3-way switches next to the front door and the door to the garage.
It seems to me there must be something happening with the wiring in the outlet where every fixture fails. Initially they work fine, but overnight they stop working completely. With 3 in a row dying on the same outlet, one of which was working ok on another outlet, I don't think the problem is the fixture. I would appreciate any ideas on how to troubleshoot and repair the problem. |
| "It seems to me there must be something happening with the wiring in the outlet where every fixture fails. Initially they work fine, but overnight they stop working completely." Sound like a sensor that is not compatible with a CFL. Just about every dusk-to-dawn sensor uses a solid state Triac to electronically turn the light on and off. Triacs distort the voltage wave, even when they are fully on. Try a CFL bulb that is rated to operate with a dimmer and you might have better luck (they are deigned to cope with the distorted voltage). |
| One other thing that can cause any florescent light to fail quickly is inadequate grounding. It makes it very hard to start up the arc inside the lamp, and can result in prolonged and repeated starting cycles. |
- Posted by geeman1082 (My Page) on Fri, Sep 9, 11 at 11:23
| I agree with brickeye, the fluorescent lamps are raising cain with your relays. I use an X-10 wall switch to automatically switch 7 CFL downlights around my house, and I had to use an "appliance-rated" switch, which has a third wire for ground (or something like that ... I'm not an electrician). If you look at the ratings of your sensors/fixtures, they will likely say something like "150W incandescent" or "150W resistive", which indicates that they won't play nice with CFLs. |
| ""appliance-rated" switch," The appliance rating probably means the part has an actual relay and not an electronic (Thyristor) switch. |
- Posted by geeman1082 (My Page) on Fri, Sep 9, 11 at 15:10
| Correct ... it's definitely not a solid state relay, and makes a very noticeable thunk (sorry for the technical term) when it actuates. |
| "Correct ... it's definitely not a solid state relay, and makes a very noticeable thunk (sorry for the technical term) when it actuates." Bingo. A thyristor takes about 0.7 V to start conducting (or ore). That means the current cannot flow until the voltage hits at least 0.7 V (sometimes higher).
Return to the Lighting Forum
