| Time to put in the recessed lighting for my new kitchen: my builder is pushing line-voltage halogen lights over low-voltage halogen, citing cost-savings, space saving, and comparable light output and energy consumption. I'm thinking of combining halogen for task lighting with incandescent hihats and pendants for general ambient lighting. Any ideas? |
| Go low voltage. Yes, they're more expensive, but you get more. They last longer, put out less heat, are more efficient and give better light than incandescent. Don't forget that a 4" hole in your ceiling is visibly much nicer than a 6". The low voltage halogen bulbs send most of the heat up, into the can. Line voltage bulbs send all the heat down... to the top of your head. That's why, if you look at the cans, the low voltage ones are much bigger- even though the bulb is so much smaller. And very soon there will be LED replacement bulbs/ modules for the low voltage fixtures. I wouldn't combine the halogen with incandescent. The incandescent has a different color temperature and is bigger (and not as bright). And when you dim a halogen, the light becomes a very soft and inviting. Keep in mind as well that an incandescent bulb continually emits less light. As the filament burns off and settles on the inside of the bulb (the black stuff you see), it blocks light. The halogen doesn't do that. The burned off filament keeps recycling back until it finally dies. That's how it lasts so long. |
| Thanks, lightguy. But can you comment on the difference between line-voltage halogen and low voltage halogen? They both have 3 to 4-inch diameter openings. |
- Posted by modern_miss (My Page) on Thu, Aug 13, 09 at 0:16
| I have the same question. Line-voltage halogen is less expensive. Is there any reason to go with low voltage halogen now that line-voltage halogen is available in 3-4" diameter openings... |
Return to the Lighting Forum
