gap between pier and post mount light
Posted by drmeow3 (My Page) on
Sat, Aug 14, 10 at 21:17
Hi all,
I have a post mount light on a brick pier. I just replaced the light and the new light has a slightly shallower base than the old one. As a result, there is a gap between the top of the pier and the bottom of the lamp (click on the picture to see a bigger copy):
Uploaded with ImageShack.us
I'm trying to figure out a way to fill in the gap (right now it's about 1/4" - it can be made bigger by lifting up the lamp a bit if there is an option for filling a larger space).
I was going to fill in the space with with a siliconized acrylic caulk and paint it but ... honestly I find caulk to be a bit of a pain to work with in a situation like this and it seems like a bit large of an area to fill with caulk (1/4" high, 3/8" deep, about 11" around). I'm also not sure how much of a pain it would make removing the light at a later date.
I thought about putting a post mount adapter there but I suspect the post mount is a bit tall and the adapter would have a huge gap, too.
Does anyone have any ideas about how to fill in the space?
I've cross-posted this on the home repair forum, too.
RE: gap between pier and post mount light
That IS kind of annoying. It's also a great place for yellowjackets to move in.
Could you use a hacksaw to shorten the top of the existing mount? Just be careful of the wiring. Maybe wrap it with a few layers of duct tape before starting.
YIPES - I hadn't even thought of yellowjackets! Shudder!
Someone at the home repair forum suggested cutting the top of the existing mount but I wasn't sure how ... duh, a hacksaw. I actually knew that. I guess I could try it but the existing mount seemed pretty thick. And, of course, now that it's attached, my motivation to lift it back off is really low, especially since unless I get up a lot earlier than I can usually manage (i.e., at 5 or 6 am), the temp ranges from 90 - 108! The thought of standing out in the heat sawing away with a hacksaw makes me think "There's got to be a better way!"
At the home repair forum someone recommended that I put backer rod in the gap first then cover it with caulk. Since the existing mount pretty effectively supports the weight of the lamp :), I don't need to put anything there which provides support so I think I might try this option. Or maybe I'll do it temporarily till the weather cools then try the hacksaw route.
Whacking the top off of it would go a lot quicker and easier with a Sawzall or equivalent. Makes a nice excuse to add one to the toolbox. :)
