Recessed Can Heat Lamps for the Bathroom?
Posted by carova_2008 (My Page) on
Wed, Aug 26, 09 at 19:20
Has anyone used these? How do you like them?
Red or Clear bulb? Which seems to work better?
RE: Recessed Can Heat Lamps for the Bathroom?
The IR Red Bowl bulbs are more intense. They cost about 3 times the price of clear. Clear is fine for lower, 8FT ceilings. Be sure you are putting them into a fixture that is designed to handle this much wattage and heat. 250 Watts is standard for these bulbs.
Here is a link that might be useful: My Web Site
We had these when I lived in Florida. I put them in my house in Atlanta and they weren't warm enough. I ended up changing to the heater/fan. I guess it depends where you live and how tall your ceilings are.
The white 250 watt heat lamp is a brooder lamp, while the red infra lamp has a protective coating on the lamp to prevent shattering.
There is no recessed fixture approved for a insulated ceiling.
They both will provide additional heat on your bathroom, but will not provide adequate heating on their own.
