Curved Vaulted Ceiling - Need Light Ideas
Posted by montel (My Page) on
Fri, Aug 5, 11 at 14:08
OK I am getting some great help in my thread on LED lights, so I now have a new struggle...
We need some ideas for lighting our great room - it has a large curved ceiling with exposed curved beams. We will have spray foam insulation that will fill the entire cavity above the beams (rafters) - and it will be sheet rocked between the beams - we can't put in recessed lights, and may have trouble with some junction boxes - so we may have to direct wire (no boxes). The space is really open so there aren't a lot of wall areas to put sconces, cove lights, or other fixtures.
Photos below:
So far one idea is to put a led strip cove light along the flat beam at the bottom of the curve.
Another is to put up a mono rail type track light like the Kovacs GK P4078 which has 8 lights and the track is 20' long. We could curve it and suspend it from the beams...
Looking for other ideas! Thanks!
RE: Curved Vaulted Ceiling - Need Light Ideas
Suspended lighting bar?
Cove lighting would be really nice though.
Pity you can't leave it - the rafters and beam looks great.
Look into the "wire" track lighting fixtures like this. You could run them inconspicuously perpendicular to the beams, or along the bottom or side edge.
http://www.csnstores.com/Bruck-Lighting-High-Line-Rony-Spot-Light-BBB1 237.html
So far here is what we are thinking:
Use the Kovacs GK P4078 mono-rail track which has 8 lights and is 20ft long - Running it across the beams at some level.
Use 2 uplight sconces on the right and left walls at about 9ft high (left wall is in the pic above).
Some cove or spot lighting at the bottom of the beams highlighting the ceiling curve. I think that would do it. See below for sketch on photo...
How about cove lighting on the other side too for symmetry?
davidtay - That is an good idea - hadn't thought of it! Will look at it - of course costs go up again...
Was looking at the LED Strip Lights in roll form that are like $114 a reel (5 meter) is that the best option for cove lights like this do you think?
LED strip lights that come in a roll are typically low voltage DC.
Some may not be bright enough to provide sufficient indirect lighting. The more powerful strips will need to dissipate heat through the the PCB they're attached to. That in turn means that the PCB becomes less flexible and potentially more fragile.
In addition, you'll need extensive wiring, multiple power supplies and planning - to account for line current loss and voltage drop. All of which will need to meet electrical code.
If I were to do it, I'd go with the Philips Powercore lighting system which uses AC power instead and is probably more practical for large scale deployment in homes.
Here is a link that might be useful: PowerCore lighting
Use this link instead
Most current link included
Here is a link that might be useful: ewcovemxpc
