Air tight recessed lights on first floor
Posted by Pendleton123 (My Page) on
Sun, Aug 26, 12 at 12:39
Hi all, been looking for an answer to this but can't seem to find. I remodeled my 1st floor and put some recessed can lights in. The contractor put in IC, non-air tight cans. Should I put in airtight trims? I know it isn't as big a deal as drafty cans that are under an attic, but I have to wonder am I just wasting energy by essentially turning the formerly unconditioned interstitial space between 1st and 2nd floor into a conditioned space. Any thoughts or links appreciated. I ask because the air tight trims in the style I want are twice the cost of the already spendy non-airtight trims. It adds up quick.
RE: Air tight recessed lights on first floor
"formerly unconditioned interstitial space between 1st and 2nd floor into a conditioned space"
It is already conditioned space.
Anything within the buildings thermal envelope is conditioned space, even if you do not directly heat or cool it.
As brickeyee said, you are already heating that space. The R-value of the flooring above is maybe R-2 to R-3, and the sheetrock below is R-0.5. If it isn't well sealed from the outside, adding holes in the ceiling will create some additional loss, but it is already about the same temperature as the house -- maybe warmer if you have heater ducts in there.
Great, thanks guys. My HVAC ducts are in there - insulated flexiducts.
I went and got the non-air tight trims (Halo 353SN - very sharp)
