| Interested in the LR6 or CR6. 1-2 months before electric work starts.
Do I need to get the Cree housing separately? Or can you use a different brand? Can you use Cree housing and install either the LR6 or CR6 or does it have to be specific? If I want to do cheap lights in basement for now, but upgrade later to Cree...can I use any type housing or should it be Cree? What is the difference between Edison and GU24?? Thanks! |
| Edison - screw in base GU 24 - 2 knobs on the base. Push and twist. A 6" Cree housing (or HALO or any other brand) will work for either LR6 or CR6. |
| Thank you! Regarding the housing..is one better than the other? From the website, there doesn't appear to be a difference in looks with the edison vs GU24. This is for new construction..so starting from scratch..not sure which one is 'better'? |
| If you're subject to title 24 type laws, GU24. Otherwise, it's your choice. In the long run - 30 years or so, GU24. |
| thanks again =) |
Return to the Lighting Forum
