Putting CR6's in LR6 housings? (Dimming Concerns)
Posted by oldbat2be (My Page) on
Sun, Aug 14, 11 at 9:49
(Originally posted in Electrical Wiring forum; moved here).
We have put up 21 Cooper Halo H71CT recessed new construction housings; original plan was for Cree LR6's. Electrical wiring is in place.
My question is: can I instead put CR6's in the same housings? The requirements for the CR6 is: 'Standard 6" downlight housing'.
The reason for the change is that I have 4 zones with only 2 or 3 CR6's (in each zone), 1 zone with a single CR6, and I am concerned about dimmability, in these zones. (I like dimmers everywhere).
Cree lists the Lutron Skylark SF-10P/SF-103P as a recommended dimmer for the LR6, and specifies (min) 1, max(12) fixtures per dimmer.
If these dimmers actually work, then I will stick with the LR6's... otherwise, I'm leaning towards cancelling my LR6 order and going with CR6's.
I found a reference to the LR6's being phased out -- I assume due to higher cost? -- this concerned me a little, too.
If it's too late to cancel the order, well I guess we'll be installing a couple of LR6's and should be able to answer the question in a couple of weeks ourselves :)
As always, thanks in advance.
RE: Putting CR6's in LR6 housings? (Dimming Concerns)
The cr6 fits in the same housing as the lr6.
The cr6 is less efficient than the lr6 but has a greater dimming capability.
The lr6 has greater light spillage since the recess is shallower. Hope that helps.
I'll reply to your other question later
Good to know, thanks. I did reach out to CREE as well, who says that the recommended dimmer should work, even with a load as small as 1 LR6. I'll post results once lights are in. (I'm sticking with the LR6's).
