| I was at HD yesterday and looked at the Halo H7ICAT cans for my project. I was going to use these air tight cans since they are the typical can standard and I then would be covered if I was unhappy with the LED Cree lights and could use other options.
I noticed stamped on the box that that the warranty will be voided if used with non-halo trims, their own Prod LED retrofit kit as well as other brands. Not that these can's really go bad to worry about a warranty issue but the only issue could be the thermal protection device built into the can. I see these cans are listed as compatible with the LR6 so don't see why they wouldn't be compatible with a CR6. So is there any big deal with using these cans? I g=figure its just that Halo/cooper lighting doesn't want to be involved in calls/issues if another light was used. Or am I better off looking at another can that would give me options? |
| That warranty void stamp is there for two reasons. 1) They want you to buy their own trims Sorry, can't give you any specifics on CR6. |
- Posted by polar_sean (My Page) on Fri, Aug 12, 11 at 16:29
| Shouldn't be a big deal at all. As you said, what can really go wrong with a can? And the CR6 shouldn't cause any problems in that can. |
Return to the Lighting Forum
