| I hope I can explain my issue well enough to get some good advice!
The foyer in the house I am building is 10' wide, and 11' long. The wall height is 11', but the ceiling is groined to 14'. The door end has a 8' high double mahogany door with an arched transom light above. Four sconces are spec'd by the architect for the foyer. I would like to be able to brightly illuminate the room, and direct the eye to the groined ceiling. My inclination is to use uplight sconces supplemented by a 60W table lamp on the reception table. 1st Question- how many Watts should each sconce produce at an installed height of 7' in order to light the ceiling and provide ample lighting below? 2nd Question- Is my proposed installation height of 7' correct? |
| If you're thinking about incandescent or halogen, quite a bit > 200watts. If you're willing to consider LED, you have many other options. For example, you could have LED trim molding. |
| Thanks David. I am using LED in the recessed, and would LOVE to use it in trim uplight. I will search the archives here to try to find more info on that application. |
| LedFolio makes LED trim molding in lengths of 2', 4', 6' and custom sizes. www.ledfolio.com There are other possibilities |
Return to the Lighting Forum
