Here is a link that might be useful: JPG of Kitchen Electrical Layout Plan
| Why are the lights so close to the wall? I think you'd need some spread around the middle of the room. I'd rather start at least 24" or more from the wall. In my situation, I tried placing the lights in a fairly regular fashion across the room. An exception was made for the light over the sink. Since I had wall hung cabinets, I ended up with the lights starting around 30" from the wall. How much light do you anticipate coming from the wall washers. Are they to be turned on together with the main lighting? |
| Have you considered using track lighting to augment the recessed lighting? |
| Hi davidtay, thanks for responding! Re track lighting, while we did think of it, we've ruled it out because this is an 1880's house and tracks would look too modern. I appreciate your comment about spread in the middle of the room. That's an area I've been wondering/worried about. I can see doing a single ambient in the center, Schoolhouse Electric-like, to give some light overall and some old-fashioned ambiance. What do you think? How much light do you anticipate coming from the wall washers. Are they to be turned on together with the main lighting? Wall washer on the "upper" wall in the pic--not sure how much light from that. It came out of my husband asking the architect what about if we had some artwork on that one, long-ish wall, so I think the light is going to primarily be for that. (Yes turned on with the main switch, afaik). I think the architect's idea on the cans is: - For the counters along the right-hand side, there's undercab lights for task (with their own switch), plus the cans above, so those seem more on the edge of the counter (at 24 in.) As it's easier to add a light in the center now than after the job's done, one central might be best for peace of mind. Any downsides to that? Other than cost of one more fixture? Thanks! |
| If this is an 1880s house and you're looking for something that isn't too modern, why on earth are you considering recessed lights??? As on old-house lover, I suggest checking such vendors as Rejuvenation Lighting for more period-appropriate fixtures. (There are others, that's just the one I happened to think of offhand.) |
Here is a link that might be useful: Rejuvenation Lighting
| I think you need to tie the other components of your kitchen together with the lighting. ie - If you have contemporary look stainless steel appliances, faucets, ... it would be more consistent to have lighting that fits. If you're looking for a more period look, like davidr asked, why recessed lighting? If you're looking at lighting pictures, there are led micro track lighting that could work very well. However, you need to consider whether the kitchen would have a consistent look vs a mix of modern and period. |
| Hi, davidr, thanks for the mention of Rejuvenation. Just discovered they have a great wizard there where you can input the dimensions of the room and the period and it'll give some suggestions. Cool stuff! If you're looking for a more period look, like davidr asked, why recessed lighting? A long while ago, when first imagining this remodel of the kitchen, I had thought of going more period and using the Schoolhouse Electric classic forms of surface-mount fixtures. (Even though the house is that old, the current kitchen is circa 1950's from the previous owner's remodeling at that time--so the question is where to take it?) To do really it as it was when built in the 1880's, it would have to look like gas lights (there's still some old gas lighting tubes in the basement). We started thinking recessed lighting when it seemed that was the most "unobtrusive" source. There's a nice river view outside the windows, and my husband is rather tall, and we think that anything pendant-like would intrude on enjoyment of looking out the windows. And I've got photos in cabinet brochures and magazines of kitchens that combine recessed lights with a few period-type of fixtures over the islands--and it seemed a reasonable choice to sort of have the light just "be there" without fixtures calling attention to themselves. One of our neighbors did something similar and it seems to work (at least, when you're sitting in the kitchen and eating there!) I think you need to tie the other components of your kitchen together with the lighting. ie - If you have contemporary look stainless steel appliances, faucets, ... it would be more consistent to have lighting that fits. Yes, your comment is spot on. That is where my personal challenge is--I don't know if I have the best "decorator's eye" to see how to tie them together. So, I look at photos from different sources and see what seems to resonate. Thanks for your input, both of you. I really appreciate it! --Lee |
| Here's how I did it. 1. Figure out what style I preferred. 2. Discuss with my wife. 3. Figure out the budget. 4. Look for the things that fit the common style. After all, we figure that we should be happy with the choices and not have to keep remodeling it. |
| davidtay, thank you for sharing that about your process. That has been most helpful. It led to a very good brainstorming discussion with my husband, which I think will lead us to be "happy with the choices". :-) Thanks again! |
Return to the Lighting Forum
