Tue, Jul 5, 11 at 20:48
| The new garden window was installed (mostly) today. I need to choose the light fixture above as the electrician is going to be on site next week. Do I go with a flush, semi-flush or pendant here? I am open to any and all suggestions.Pics would be great as to what you've done over your sink. I did cross post in kitchens.
The main fixtures are Medya Celtic Knots. If that helps at all. TIA
| Do you get a lot of natural light? Are you going to use window treatment on the window? I would personally do a recessed light there since you do not want to detract from the window and the other unique lighting in the room. Good luck! |
| Thanks Sara! No window treatment there, just herbs. I'll run it by the electrician tomorrow. |
| A single light source (other than a physically large source like a florescent tube) will throw harsh shadows. I routinely place two smaller light source over sinks if there is not going to be a larger fixture. |
| Thanks fir your help brickeyee. |
| Brickeyee can you be more specific on the light sources you use? |
Return to the Lighting Forum
