| Hi,
We have a 2 story great room and (19x21) we are planning on having one large ceiling fan with light along with 7 wall sconces on the walls. Do you think this will provide enough lighting? Is there a standard height for wall sconces in a large room? Any cons with going down this route versus 9 recessed lights?
| Probably not if all the light is coming from the sconces. Assuming each sconce takes a 60W incandescent bulb which produces ~ 800 - 900 lumens, you have between 5600 to 6300 lumens. That does not take into consideration shading due to the sconce or directionality - whether the light is directed up or down. If you want ~ 20 lumens per sq ft, 19 * 21 * 20 = 7980 lumens. The ceiling height could be problematic for recessed lights as most installations are for ceiling heights < 10' and servicing the lights could be challenging. |
| There will be a light with the ceiling fan. Great room ceiling is about 18!feet. Is there a standard height for sconces? Davidtay, what type of lighting do you recommend for 2 story great rooms if recessed lightings may be problematic? Thanks for the feedback! |
| The placement height depends on the size and style of the sconce. The ceiling fan will need a pretty long "neck" and shadow patterns may result. Several possibilities 1. Cove lighting - you can imagine it as being a continuous sconce along the wall. 2. Use LR6-DR1000 or similar recessed can. 3. Chandelier/ hanging fixture 4. A combination of light sources such as cove lighting + Chandelier/ hanging fixture. |
Return to the Lighting Forum
