| Hi Everyone,
I am looking for under cabinet lighting help. Here is my situation: I have two separate runs of cabinet that I need u/c lighting for. I really do not want to put anymore switches on my walls. I would like LED and I would like it dimmable. I already have the 120v circuits (14/2 romex) run in the wall to the locations. Can I hardwire the transformers to the circuit without using a conventional wall switch? I was thinking about putting a low voltage switch after the transformer. Any other suggestions to keep these switches off my walls with a dimmable LED? Thanks, Ed |
| What you do is put in your LED undercabs in and the driver is inline before the light, than the driver is hooked up to the undercabs. You don't need to add anything other than the original switch that will switch on and off the undercabs. Sometimes the drivers or low voltage transformers (depending on type of lights used) can be placed inside the cabinets. You can also get LED undercabs that have the drivers built in, so no drivers need to be wired in. The new Philips ones are pretty good. Be sure to match the overhead lighting color temperature with your undercabs. You don't want a 4500k overhead light with 3000k undercabs, it looks bad. Mike |
Return to the Lighting Forum
