| [cross posted in Kitchens forum]
I am in the homestretch now -- down to the final decision on UC lighting (which must be made tonight, as we need the fixtures for wiring on Thursday.) I am between three choices -- 1 - Seagull Ambience dimmable xenon linear system 2- Seagull Ambience NONdimmable LED linear system (same as above, but non-dimmable and less power consumption) 3 - Diode LED Refract Light Bar -- dimmable LED bars in varying lengths from 10-30" (1/4" thick brushed aluminum bar) I like the low-profile (almost invisible) appearance of the Seagull Ambiance, as it basically hides behind the light rail under my cabinets. I like the low-voltage of the LEDs, but the dimmable aspect of the xenon. Also worry about the xenon bulbs getting hot, and the cost of replacing bulbs (more often than LED). The Diode LED system combines the features of dimmability and low-energy consumption, but I worry that the bar style is more obvious/less attractive than the Ambiance tracks, and I can't find much in the way of reviews for Diode LED. One of the things I am not sure about is whether I really need my undercabinet lighting to dim. I think I would like to have the option, for example when entertaining, or at night, but I am not sure (never having had UC lighting.) If you have undercabinet lighting, do you dim it? Any thoughts or advice otherwise on the 3 choices above? |
| Got lots of feedback over at the kitchen forum, and after more consideration have decided to go with choice #1 - the Seagull Ambiance dimmable xenon lighting. |
| Hello (I posted earlier on the Kitchen forum), for future information that others may want: I have the # 3 option, DIOED LED Refract Light Bar on a dimmer the company offers and I love it!. The name of their dimmer is Reign, & yes was expensive. I like the Refract Bar because it is over my sink and will be only modestly visible if I look up. I wanted the light to have a finished look and this one is nicely finished for my needs. I got the non-dimmable driver with my system. I am happy with my set up. I also have a separate dimmer for my under cabinet lights and used the Diode LED Cascade Light Bar for these locations, because they are water resistant and dimmable. I went with the warm light option on both styles. |
Return to the Lighting Forum
